Running MAX Rich..
Boost95
403
Oct 21, 2004
Wilkes Barre, Pennsylvania
92 TSI AWD. EvoIII, 650's, Rewired 190lph, 18 psi,afc,wideband,logger.
No matter what adjustment I put in the AFC I am running very rich. No boost leaks, I just tested it. On my wideband the highest it will read is 10.0 which is what it will read at WOT. Fuel trim is at 81%.
Here are some concerns that may be a factor. I recently noticed that my SAFC does not read Throttle %. I checked the grey wires connection and it is solid. My logger reads the TPS correctly.
The car is very slow like this and id like to get it running in its best shape.
Thanks for any help.
-MIke
Its installed correctly, Its been in for about a year now.
The sensor is fine. It will read correctly on my logger. Only the SAFC is reading 0.0%
:thumb: SOLUTION:thumb: Took the 4 bolts off the afc and removed the cover. The connector where all the wires connect to the AFC was falling off. I put it back on properly and everything works!
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
