running isues
BryanCenterfitt
45
Mar 27, 2009
cordele, Georgia
..ive got a 94 eagle talon dl. not a fast bugger but its okay. Neddless too say im haveing a bit of an issue at WOT. Ive checked to see if there was any Vac. leakes, none....checked the TPS, its good, checked the timing, its at 3degrees BTDC and checked the MAF, its working as it should.
now the problem juts started and im not sure wich way i should go. could there be something im missing? can any one shed some light on this?
thanks
Bryan
it stumbbles real bad around when really getting into the throttle, now if u r just crusing its fine, or if u let it get up to about 3500rpm it runs fine
