Rough Idle?
DSM S2
May 28, 2008
Lincoln City, Oregon
Hey I just got myself a 92 eclipse gsx and it has a smoked turbo that is still running full boost, but my main problem is that its running really rough at idle... like its wanting to die on me unless i keep it out of idle... on the road it is running great its just the idle. The ecu has just been replaced thinking this could have been the problem, any ideas? Thanks
Go to vfaq.com and follow the instructions to test your ISC, adjusting the biss screw could just be a band-aid to fix a problem, however it's possible that the biss screw was just adjusted wrong, but I would check out the ISC and do a boost leak test to be sure. If you're not recircing your BOV it will also have a rough idle, so check out those couple areas then adjust the biss screw if nothing else is bad. Good luck
had the same prob- turned out to be a vacuum leak, so i fixed that, and then got another leak that turned out to be the intake manifold gasket- replaced it and that fixed all my problems.
for sure do a boost leak test, mine had the same problem. the car was running really really bad but when i fixed the boost leak all problems such as too much gas,idle jumping up and down were fixed along with the leak.
what are a list of problem areas because i'm having the same problem but i did the boost leak test and theres a small hiss inside the intake it seems. i tried to feel for leaks but there was no air coming from anywhere.is there another way to trace the leak
