2G Rotors won’t fit over e brake
Bedicine
539
187
Jan 3, 2022
Toronto, ON, Canada
Hello
So I’m in the process of installing new brakes in the rear on an awd 2g. I’ve rebuilt the parking brakes (all new) and was able to get new Mitsubishi dust shields. In addition to this I’m going to be running the evo calipers, I did have to modify the dust shields to fit.
The issue I’m having is I can’t get the rotors over the parking brake shoes. I’ve got them set to the loosest setting at the parking brake handle and with the adjustment on the parking brake itself and I still can’t get the rotors over. It’s very close but I’m wondering if anyone has any advice or an adjustment I’m missing.
Rotors are
EBC 2K-EBC-GD996
Thank you
there's at least 2 size "drums" for disc brakes, search by part number, not by "fitment" I'm more than happy to give right part number but just let me know year and trim or vin number would be better, specially on -95 there was 2 different sizes if I remember right
Brake shoes: MB950212
Rotors: MB895200
Original part numbers
Still when you're purchasing them make sure that drum size matches your brake shoes
Also before you go ahead and buy another set, have you screwed the adjustment all the way in and centered it? Also measure drum size and shoes what you have now
So, if you have a very early 95 you might have the more massive vented rotor like was used on the 3000GT/Stealth.
if you have 06/1194 - 12/1994 model, then I think your best shot is to cross fit the part number or just measure the disc and get the closest one or just put newer model brakes on it because those brakes are discontinued as far as I know
It’s not the depth of the rotor it’s that they won’t clear the parking brake. I also have the evo calipers so the rotors are a bit different in size.
Two photos attached showing top and bottom of parking brake. I don’t believe I have any further room to adjust?
measure your rotor drum and width of brake shoes
So I was lucky enough to try a stock rotor and I’m having the same issue. It won’t fit over the parking brake shoes. It’s not the depth but the parking brakes are catching on the inside of the rotor.
Any suggestions to compress them?
Looks like they're fully compressed. So it's either the shoes, the rotors, or both. Do you have the old shoes still?
Old shoes were just bare metal. Rotors I have an oem brand new one and the evo one here for the rear brembos. Both won’t fit over the shoe.
All new parts were purchased are labelled for a 2g dsm. The parking brake hardware kit is from stoptech. Did I do the rebuild wrong LOL?
It doesn't look like you have the adjuster installed correctly or the upper springs on in the right order. The adjuster fits so that the slots are vertical and that will pull the lower edges of the shows in.
Appreciate that. Let me take a look tonight and see if I can make the correction
Good eye. You're absolutely right, the adjuster looks to be in the wrong spot.
So I found a picture of the brakes during when I rebuilt them. Hadn’t locked in the shoes yet but to give an idea of how I did them
Got it moved up
