2G Big Brake Rotors?
DSMpwr25
110
Oct 29, 2004
Gloucester, Virginia
I am trying to find some big brake rotors like 13in with out having to buy the capliar too. and could i use some VR-4 4 piston capliars for the front? thanks for the help
p.s. its a 95 TSI AWD, if that helps break it down :thumb:
For one piece designs you might want to try the Vette rotors- works for Baer.
If you want two piece set ups there are a number of us who can supply you with what you need. Finding proper offset of the hat may prove the more difficult deal. Rotor OD and width can be spec'd pretty easy. Hats are not so easy.
If you're really sold on the Mits VR4 parts why don't you compare the aftermarket rotors offered for that car and see if they will line up for you? I honestly don't know if they will or not. Something tells me 'no'.
Getting two piece set ups is not hard but expect to spend about $550 for a pair.
