rods...
AlexGsxCummins
395
38
May 31, 2014
Bremerton, Washington
Alright so incase this horse is still breathing lets beat it again. I'm getting pretty close to getting rods and at first I was set on the common eagle rod. But now I'm starting to wonder if its safe to run them up to what I hope its 600 hp so that is what I'm planning my build on. Or should I go with a I beam for this goal?
Some H beams will be up to the task depending on how aggressive you tune and rod speed, (RPM)
I like the BC line of rods, they are the closest in matched sets right out of the box.
Also if you build the 6 bolt, BC has the "swap" rods so you can run the 22mm wrist pin.
