Resolved Revised 7-bolt main bearings in older 7-bolt?
DSM IN MN
Supporting VIP
705
23
May 17, 2009
Wadena, Minnesota
I have read one thread somewhat pertaining to this. It threw me for a loop however because it was for a 4g64 out of a Galant rather than just a 4g63.
Any who, I plan on starting a semi-build for the engine to swap into my Talon in the near future (a year or less hopefully). What I am a tad confused about is what main bearings I want, should and can use.
As of right now I have a block out of an Evo. III. The engine that is in my Talon is the original, to my knowledge at least. The car is a 1995 with a 1994 build date. Originally I had planned to use the Evo. block as the block everything will go into. Then from there I could just (in theory), swap it over. Lately I have been wondering if I could use different main bearings in the Evo. block to avoid the possible crank walk issue found in the earlier 7-bolts (1995-1996).
I know the issue came up because (as far as I know), people would install clutches that had too heavy of clamping force which in turn would push the crank so much so that it would wear down the thrust washers. Which then would allow the crank to move, eventually destroying everything.
In 1997 they moved to the one piece thrust washer/main bearing design. This improved or got rid of the threat of crank walk or at least this is what I understand. I recently have read that Mitsubishi revised this setup/design again in 1998-1999 though.
So after all of this, what I am wondering is, is which bearings can I run in my (Evo. III) block? Do I have to stick with the earlier multi-piece thrust washer/main bearing design, or can I switch to the 1997 or 1998-1999 single piece setup?
Solution
The 98-99 block and main girdle are machined slightly differently to use the three piece thrust main. The issue with the three piece thrust main bearing in a pre 97 block is the two "new/separated" parts of the thrust bearing wouldn't have a surface to prevent rotation and would rotate with the crank.
No, you have to use the main bearings the block was machined for.
Solution
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
