Review of Stage 3 Keydiver Chip
JohnCIV_Talon
Banned Member
340
Mar 22, 2007
Sanford, North Carolina
Today I recieved my eprom ecu and stage 3 keydiver chip. I was going to wait til this weekend to install that and my injectors, but I got impatient. It ended up only taking 50 minutes to do swap both.
As far as customer service and shipping, it was top notch. It got here in 2 buisness days. There were a couple problems on my be-half but he kept communication everyday.
After the install, there were no problems at all, the car fired right up and idled even better, even with 750's installed now. I did a couple Wot's just through first and 2nd and the car felt a lot smoother. Before it was kinda notchy in a few spots, but now it is a smooth climb all through the rpm's.
I will try and do a couple logs tonight, just to see what my timing curve looks like.
Jeff is a good guy and has great customer service. When I installed my chip with 850cc injectors the car fired right up on the first try and idled like stock 450's. I have yet to log a pull, but the car feels good. My stock boost gauge is set to monitor knock and showed a little knock in 4th gear at 5500rpm, but there are other issues unrelated to the chip that's causing that, ie boost leaks.
I highly reccomend DSM Chips.
Ya i have a few boost leaks, actually one in my throttle body gasket. Im fixing that this weekend. I forgot to mention that it really seems to have a lot better throttle response to. Also my boost gauge was no moving at all, so I gues i have no knock.
Heres my log, Keep in mind its in 2nd gear, no third til 2 weeks from now. only 14psi on a t-25. How does i look? What are the downsides to doing a log in 2nd gear?
2648.0 35.0
2676.0 35.0
2700.0 35.0
2724.0 35.0
2792.0 34.0
2860.0 29.0
2956.0 23.0
3052.0 17.0
3180.0 13.0
3340.0 9.0
3496.0 8.0
3692.0 8.0
3900.0 8.0
4088.0 3.0
4264.0 9.0
4472.0 9.0
4688.0 9.0
4884.0 10.0
5064.0 10.0
5244.0 11.0
5436.0 12.0
5612.0 14.0
5772.0 14.0
5952.0 16.0
6084.0 16.0
6240.0 19.0
6408.0 19.0
6540.0 20.0
6676.0 19.0
6808.0 20.0
6928.0 21.0
7044.0 22.0
7164.0 22.0
7256.0 22.0
7368.0 22.0
7272.0 22.0
The timing looks good after about 5500, but before there you're going to have to do some fine tuning.
A boost leak will cause the car to run rich. Get it fixed and it'll run considerably better.
Well I didnt really go wot til 4200. It climbs to fast in 2nd like you said, so im up there before it starts logging, not to mention i only went half wot til I got to 4200. I dont know why. Im sure fixin my boost leak will fix that.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
