Stage 3 keydiver set up
JohnCIV_Talon
Banned Member
340
Mar 22, 2007
Sanford, North Carolina
Hi, Im planning on getting this from dmchips.com pretty soon here. I got some important questions before I get it though.
First, My set-up will be 650's a 190 fuel pump running 18-20 psi on a evoIII16g. I was wondering if I could get some help on what to tell him to set everything to. I know there is someone on here that specializes in that but I dont remember who.
Secondly, I will be installing the eprom with the chip along with the injectors at the same time and still have the t-25 on there. Will it cause any problems having the chip set-up for a specific thing if it is installed before you have the turbo you want in there?
Andy is the 'guru' of DSMChips. :)
As for what to tell Jeff at DSMChips, tell him you run base fuel pressure and what octane fuel is available to you. If you want a custom fuel map for 11.5 A/F ratio and want to run say 16 degrees of timing, you can ask him to do that too.
And no, having the T25 now won't make a difference. The chip will compensate for the bigger injectors - It doesn't matter if you want a T25 or a 50trim.
People are reflashing these things, im not sure how to do it...along with those chips
