Modify Keydiver Chip?
Nate355RS
446
52
Oct 25, 2012
Salem, Virginia
I have a Talon with ECMLink and and I recently bought a Galant VR-4 with a keydiver chip. I want to switch ECMLink over to the Galant so I can tune it, but I want to keep the tune on my Talon. Would it be possible to put the Talon's ECMLink tune on the Keydiver chip?
I have a chip burner and a little bit of OBD1 knowledge from when I use to tune old GM cars. I'm just not sure how to transfer the tune from Link to the chip. I don't need to copy all the ECMLink bells and whistles, just spark, fuel, idle, injectors, AFR, and other general driveability parameters.
Depending on the chip, it may or may not re-programmable so you might need a fresh chip to start with. You can hand write the maps from the ecmlink tune and manually transfer the areas needed to write a new chip. If you're asking if there's some easy way to essentially copy/paste the ecmlink tune over to an obd1 chip burner I don't think there is.
That's no problem if I have to do it all by hand. I'm having a hard time ID'ing the chip. It's a 28 pin with serial numbers:
8J5223-3-34003B
1-P0942 E3
I can burn most 28 pin ST 27SF512, ATMEL AT29C256 and 29F040 chips. But I don't want to stick an unknown chip in my burner to read unless I know what it is, I really don't want to fry the chip.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
