[RESOLVED] Reverse deep rumble sound (backfire)
mattdev
349
Jul 15, 2006
San Antonio, Texas
For the past few months when I am in reverse it sounds like I am constantly backfiring. It started when I installed my Cat-Back and has continued since.
It sounds alot like backfiring. I can get it NOT to make the sound if I slip the clutch a LOT until it's in gear, and then have to be EXTREMELY light on the gas, or it will make the sound every time the car jerks backward. If I give to much gas the sound will continue for a second even after the clutch is in
Sounds pretty noob but it's pretty hard to explain... haha
I have a blowthrough setup, so yeah, I'm VTA.
On closer inspection it could be a differential problem. It happens most when I have the wheel cranked in one direction (in reverse). The same sound also happens when I let off the gas too quickly at boost. Makes a huge bucking and creates the same sound.
