Resolved reverse lights fuse?
Are you reverse light not working at all?
I would check if the connector is still attached to the trans for the reverse lights. It is located on the If it is connected I would them disconnect it and do a continuity test to see if there is resistance and proper ground.
Back-up lights are on the fuse labeled "Back" on the inside junction block (passenger compartment fuse box).
