[RESOLVED] no oil pressure
outkastracing
244
Dec 13, 2007
Aberdeen, Washington
alright so ive been building my engine got it all done and started to turn it over! well turns over nice except theres no oil pressure! none even in the oil filter!!! what the hell i did everything right!!!! any suggestions getting ready to pull the pan off to see if i can see anything
When I rebuilt my engine last summer I primed the oil pump using a cordless drill prior to installing the timing belt. Make sure and start off gently with the drill(just in case). I do this to all the engines I install. If I remember it did take a little while to prim the oil pump(and the rest of the system). As long as you used assemly lube when you assembled the engine just keep cranking in 15-20 second intervals until you get oil pressure.
we did that i forgot to put lithuim grease on the pump gears so its dry we just took the pan off and are going lookin for some i dont know there was no pressure at the head and we did it for ###### a min! do you know what rpm it needs to get a enough suction to start workin
You didnt grease the oilpump/siphon tube when you assembled it? Its almost a nessecity.
At least fill it with cam lube or something that will stay in there!
