[RESOLVED] Biss screw part number [Merged 8-8]
forcedfedgsx
183
Apr 29, 2003
where can i get a new BISS screw, part # would prob help i would rather go to auto zone but if i have to get it from a dealer then tell me
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Biss Throttle Body O-ring : Mitsubishi Eclipse 90-99
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Biss Throttle Body Screw : Mitsubishi Eclipse 90-99
Don't forget to use dieletric grease on the o-ring. I also recommend using some Permatex Ultra Black RTV silicone sealant to plug up the BISS hole (after you're happy with the idle setting) to prevent any boost leaks. I don't recommend buying the BISS cap. Waste of money IMHO.
Hey guys
so i lost my biss screw today and was wondering if any1 knows what size the bolt is, I found the screw on machv.com but I want it fixed today. I searched and couldnt find anything on what size bolt it is. thanks
mike
Base Idle Set Screw, it's on the throttle body.
Hmm, not sure what the part number is. I could measure it for you if that was your question. When i get home later.
BTW: I bought my throttle body rebuild from that "throttlebodys.com" guy Steve, and it came with a plastic BISS in it, and it broke into peices when I used a screw driver on it. Good thing my old one fit and I had it.
Edit: My post makes no sense now, but I was the second post. The first post asked what a BISS was.
I don't think you should try using a regular bolt here. Order a new BISS or pick one up from a junkyard. A #5 oring from your local hardware store is the correct size for sealing the shank of the BISS to the TB bore. Search the forum for the part number. Anyone with CAPS can get it. The part number might also be listed on VFAQ Site - Visual Frequently Answered Questions in their BISS adjustment article. Then you can go to your local Mitsu dealership and order it by part number.
EDIT: From vfaq.com:
Mitsu part # is MD614948 and it's called, "Adjusting Screw, Throttle Body". You need a #5 O-ring (3/8x1/4x1/16, available at most hardware stores)
  • Wanted 1g 1g Shift knob
    Looking for OEM 1g shift knob
    • Knight_rider
  • For sale 2g 2GA Turbo/Automatic Engine Harness
    2GA Turbo/Automatic Engine Harness $225 + shipping & paypal fees* all plugs are complete and...
  • For sale 4G63 6 Bolt Oil Pump Pickup ( great condition )
    6 Bolt Oil Pump Pickup $65 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G OEM BOV Hose ( great condition )
    2G OEM BOV Hose $25 + shipping & paypal fees* great conditionYou must be registered to see...
  • For sale 1g 1G OEM BOV & Vader Cap
    OEM 1G BOV & Vader Cap $45 + shipping & paypal feesYou must be registered to see element.You...
