98PieceSucka
- 0
- Apr 22, 2008
Memphis,
Tennessee
'98 GSX...I removed the intake manifold and below it right in front of the block is a black pipe about as big around as an oreo and that is connected to something on either side of the motor. This bar/pipe is dented and pretty much halfway flat in one area(obvious it's not supposed to be. I have checked haynes and chiltons and cannot find out what it is or if it carries any fluids.
Can anyone help? Also the turbo that came on the car, which was not stock, did not have coolant lines run to it nor did it have a place for them, should it have? I have ordered a 16g and also would like to know if iy will have those connections and if i'll have to re-run the missing coolant lines. Thanks DJ
Can anyone help? Also the turbo that came on the car, which was not stock, did not have coolant lines run to it nor did it have a place for them, should it have? I have ordered a 16g and also would like to know if iy will have those connections and if i'll have to re-run the missing coolant lines. Thanks DJAttachments
If I were you I would not go much further before doing some reading up on basic mechanical knowledge.
