[RESOLVED] 2G 95 Power Antenna Swap Need Wiring Diagram
darklord97929
Jul 23, 2004
Roanoke, Virginia
I have a 95 Gs I'm building for my Dad and I'm am changing out the oem mast antenna for a oem power antenna. The problem is that the power contector isn't made into the 95 wiring. The antenna has five wires going into it and I need to know what they are for. I have a old factory service manual but since it is older it does even list a power antenna. I have done a search and having come up with anything. So any help you can give me would be greatly apprecaited. Can someone maybe email me the wiring for the radio and power antenna diagrams. Thanks
P.S these are the colors of the wires on the antenna
Black w/ yellow stripe
White w/ black stripe
Red
Red w/ green stripe
Blue w/ black stripe
Thanks Again for all of your help.
Anybody? I got the same problem
New antenna I got has only 3 wires BLACK (ground I guess) RED (+) and GREEN (-) How am I suppose to connect it?
BLACK to either ground or pin 6 (black) of motor antenna connector.
RED to pin 2 (black/white) of antenna motor connector.
GREEN to pin 4 (white/black) of antenna motor connector.
I got mine today:
Does this mount up to a car without a power antenna? There looks to be two mounting areas for this.
That word document wire diagram doesn't really help at all. It is too small.
Where should I get the wires from to power the antenna?
Here's some pic of the surrounding area of where I installed my power antenna. I am thinking that I can draw a power source from the surrounding harness. What do you guys think? I am just worried about the remote wire (when its going to go up). I know I can just tap red to red, black to black but i want to know what is going to be my remote wire for this. I know stock the power antenna goes up when you turn the key to ACC, I'd like mine to do that as well. Thanks for any suggestions.
ok here is the color codes for power antennas this will help a lot of people:
eclipse 96-up
Black w/ yellow stripe --- IGNITION
White w/ black stripe----- (-) GROUND
Red ------------------------- (+) B
Red w/ green stripe ------- ACCESORIES
Blue w/ black stripe -------- ANTENNA
Thanks bye.
awesome, to think i had one laying around. Im installing it tomorrow!!!!!!
Hey its tomorrow already! sunny and hot as hell. i just spent 2 hrs sweating like b___h to realize the stupid power antenna i have didn't have the teeth belt or work at all, the motor works if you feed it direct + and -. i think the little box is bad, so i ended up putting everything back together including my non anything antenna
P.S. i never realized how many screws i used for my system until now!
this sux
Thank you guys for clearing up which wires are what within the stock harness. Did the person find out where the three wires need to be spliced to? This tread really never ended with a solution. I started up a thread similar to this with pictures of the aftermarket antenna motor with the three wires.
http://www.dsmtuners.com/forums/mai...nd-gen-aftermarket-power-antenna-install.html
I would appreciate the help.
Thanks,
Joe
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
