Resolved wiring diagram 95 eclipse rs
metalx
Aug 22, 2011
modesto, California
hello. i have a 95 eclipse rs. the idle is beyound messed up. when the car 1st start the rpms jump to 3500 rpms. after it warms up it goes from 1k-2k the car is just rezing its self. when looking in the engine bay i notice a wire connoctor that was unplug and cant for the life of me find where its post to be plug in to. i need a diagram that will show this. ### and ty
your Idle Controller may be bad..change it out and see if it still does this.
Also check the pcv valve.
And that plug that was disconnected looks like your reverse sensor plug(plugs into the right side of the tranny when facing it)
i replaced the iac sensor and the tps. i show it in the video. how would i check the pcv valve to see if its bad and where is the valce?
this little valve inline between the valve cover and the intake manifold. its just a check valve. lets air one way and not the other, test it by blowing and sucking air through it, if it leaks then replace it. 3$ at parts store
checked its air tight but there seams to be oil in the pipe. is that norm? not a lot just a bit. also if its not the valve or the iac any other place's that are knowen to have leaks?
ah thanks. found the prroblem the gasket for the throttly body was pretty much gone
Solution
