Wiring diagram
1996 Talon Printout
12 Volts:White
Starter:Black/red
Ignition:Black/white
Accessory:Blue/black
All at ignition switch
Tachometer:White
At instrument cluster or PCM. The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.
Source : Directed electronics
There is definitely an easier place to get the tach. There is a test plug somewhere(not sure where) or you could go to the negative of any fuel injector(not ideal)
