wiring diagram
daveeclipse99
74
Dec 10, 2008
grand rapids, Minnesota
im looking for a wiring diagram for the 420a . i need to find the wires to certain sensors to hook up a engine management . if anyone knows please help
thanks guys
hope this is what you need if not let me know and tell me what sensor diagrams you need and i can get them for you
MFI System
Notes
MFI System (Part 1 Of 9)
Duty Cycle Purge Solenoid Valve
Evaporative Emission Ventilation Solenoid
J/B
J/C (3)
Powertrain Control Module
Transaxle Range Switch
MFI System (Part 2 Of 9)
ASD Relay
EGR Solenoid Valve
Fuel Pump
Fuel Pump Relay
J/C (3,4)
MFI System (Part 3 Of 9)
Capacitor
Generator
Heated Oxygen Sensor(Front)
Ignition Coil
J/C (3)
MFI System (Part 4 Of 9)
Heated Oxygen Sensor (Rear)
Injector
J/C (3)
MFI System (Part 5 Of 9)
Camshaft Position Sensor
Crankshaft Position Sensor
J/C (3,4)
Knock Sensor
Vehicle Speed Sensor
MFI System (Part 6 Of 9)
Engine Coolant Temperature Sensor
Intake Air Temperature Sensor
J/C(3,4)
MAP Sensor
Throttle Position Sensor
MFI System (Part 7 Of 9)
Auto Idle Speed Motor
EATX-ECM
Input Speed Sensor
J/C (4)
Output Speed Sensor
MFI System (Part 8 Of 9)
Data Link Connector
Dedicated Fuse
J/B
J/C (1,2)
MFI System (Part 9 Of 9)
Combination Meter
J/B
J/C (2,3)
Power Steering Pressure Switch
Stop Light Switch
