[RESOLVED] Anyone have wiring diagram (Free wiring diagram PDF link)
GSTspyder17
38
Jan 19, 2007
putnam county, New York
can anybody show me a diagram or just tell me what each wire is for on couple plugs...
im working with a 2g harness and i need to know what color wires and what each wire does or where it goes... i need for example: "yel/blk=ignition power, blue=ecu signal ect"
i need info for:
alternator plug
Vehicle speed sensor
coolant temp sensor
i have an eclipse/talon haynes manual but it does not tell me what each wire is for
Alternator:
Red – 12v Constant Source
Black/Yellow – Metering of Voltage (warning light)
Green – Pin 41 on the ECU – Voltage Regulator FR
White – Pin 33 on the ECU – Voltage Regulator G
Vehicle speed sensor:
Yellow - ECU pin 86
Black - Ground
Black/white - ECU pin 82
Coolant temp sensor (for ecu):
Black/white - ECU pin 83
Black - Sensor ground (ECU pin 92)
Alternator:
Yellow - ECU pin 86
Black - Ground
that was fast reply! thanks where did you find this information at? ive searched everywhere
also whats FR and G stand for on the voltage regulator?
Well, all the information is in the DSM manual, which you can find here:
http://www.dsmtuners.com/forums/fre...stions/324090-download-2g-service-manual.html
It will take some searching, but every wire is in there. I had the answers so fast because I'm in the process of rewiring my engine bay, so I documented all the wires that I'll be reusing.
I'm not 100% sure what the FR and G stand for, so I'll let someone else answer that.
