Replacing Narrowband with Wideband
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
Do I completely replace the narrowband with the wideband? I want to replace stock 02 sensor with wideband and simulate narrowband.. Is that correct?
EDIT -RESOLVED- Caved in and bought a bung from Oriellys for $3.50 and will weld it in myself. Much easier, my headache is almost gone
you sure about that? It does have a NB sim built in the (lambda?) box or whatever its called. The way it comes out of the box without touching lmconfig should be good for you. You want the NB 0-1vdc signal to ecu front o2 and the WB 0-5vdc running to the gauge. Im pretty sure it works.....
It may work but not as flawless as you want. Unfortunately that's what a lot of people adviced against.
Yea, I never tried it so I am speculating. I suppose a second bung welded in IS the best choice regardless.
I agree, welded an extra bung won't affect the first o2 sensor and it will allow you to place the wideband sensor in the best possible spot downstream of the turbo.
Now I don't know what to do.. Thanks guys LOL. I've heard some say the nb simulation is flawless, but the other half say its glitchy and sometimes inaccurate.
Edit- Called around for some copper plate to use as a heat sink and for the size I want, I could only find one place with it and these bastards want $60... Where did you guys get your copper plate and how much? My shop no longer needs copper since we stopped using them for trailer tail light accents :banghead:
