replacing head gasket and turbo, have a list of parts.
onefast2gdsm
866
6
Aug 30, 2010
millersburg, Pennsylvania
I need help. I am changing my head gasket and upgrading my turbo, so I compiled a list of parts that I have currently and parts I still need to buy. This is where I need help, I need to know if I'm missing anything.
turbo to manifold gasket
o2 housing gasket
evo 3 16g
throttle body gaskets
water pump
water pump gasket
water outlet o rings
fuel feed line o ring
3" downpipe
arp head studs
cometic head gasket
j pipe
l pipe
couplers
oil feed line
oil return line
coolant feed line
coolant return line
gauge cup
aem wideband
crush washers
hi temp silicone
timing belt
balance shaft belt
idler pulley
tensioner pulley
balance shaft tensioner pulley
automatic tensioner
evo 8 oil filter
royal purple 5w30
valve seals
copper spray gasket
cometic headgasket
to be bought still:
cam seals
injector o rings
3/8 hose to connect turbo water lines to block and thermostat housing
5/16 hose for pcv valve (mine is dry rotted)
exhaust mani gasket
intake mani gasket
valve cover gasket set
have the head hot tanked
valve seals replaced
pressure checked
milled
sorry for the long list :/
I really don't want to take the block out of the car, do I absolutely need it decked for the MLS gasket? The car never overheated and never had bad oil pressure. Also, I plan on taking the pan off and resealing it while I already have the car in pieces LOL. Should I get a gasket or just do it with silicone? What gaskets do I need to use silicone on for added security?
Also, the ring that goes in between the turbo to manifold gasket, do I need to reuse that when putting on the 16g? Obviously the t25 one is too small and if I get one for the 16g it wont fit to the 2g manifold.
No you dont use the ring. No you dont need the block decked, but the head should be checked and maybe resurfaced.
Personally your throwing away money running royal purple in your engine. can Mobil 1 is a great choice for anything and cheaper. I wouldntwaste money on that. You own a pretty much stock car.
Oh and the oil pan uses rtv black or equivelent....as according to the oem manual. The gaskets suck.
I work at an auto parts store so I get the parts relatively cheap including the oil. This is just the beginning of me Modding the car I plan on putting 264's on and bigger injectors and a 255lph pump with a rewire..
i would buy the oem, prebent hose from the pcv to the intake manifold. Ive run regukar 5/16 rubber hose and it always gets kinked. Also you better oirt that 02 housing when running a 3" dp or enjoy the boost creep.
I'm going to attempt to port it, I'm planning on getting an external dump soon so porting it will be a temporary band aid. I looked at vfaq and saw the page on it so ill be taking a go at it. Thanks for the help man.
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
