1G Head gasket and timing belt parts list.
pitbull1990
75
May 6, 2009
okc, Oklahoma
Ok so far I'm ordering timing belt kit,engine gasket set,water pump and head studs. That comes with camshaft and balance shaft seals.
Not sure what else I'm missing and also wanting to refresh my head what is necessary I was going to get valves seals and not sure what else is a must have?
Just order a felspro hg set. It will come with everything needed to do a proper head job as far as lower end. Front crank seal wouldn't mess with the oil pump seal unless it's leaking
Ok and also was wondering if there was anything I should remove while it's apart? I'm doing egr and was wondering if oil lines etc I can replace with better ones for simplicity?
A fresh set of valve springs would not hurt. Most stock springs by this age have gone weak.
