replacing exhaust manifold studs
Its beetling sitting in a cold garage all night should i heat it up at all?
I cant get the manifold off around the stud from my turbo is there an easier way to get it off?should I take off the downpipe?
I dont think it matters too much, but you could probably let it run for a bit, shut it off and when it cools to the touch apply the lubricating oil.
When i took off my exhaust mani, it was a PITA, but I never took off my downpipe. I used a couple of pry bars. One where the manifold meets the head and one underneath the manifold. Prying up while prying the manifold away from the head until I finally got it off.
Thats just the way I did it, but hopefully some other members can chime in for a simpler method to save you the headaches.
I've always dropped the downpipe in manifold related tasks, its a pita to try and move your turbo around when its mounted to something. Just be sure to support it!
