420A Replacing clutch soon and need some help
Noobtuber
39
Mar 25, 2013
Richmond, California
Hi all. Noob here :hellyeah: 96 RS NT
I was wondering if someone could give me the part number for the bolts that go from the flywheel to the crank shaft and I need the part number for the 4 bolts that go from the flywheel to the rest of the modular clutch.
This is going on a new block so are there any seals I need to deal with?
Thanks!
Have you tried using this parts search?
Download the Mitsubishi CAPS (Mitsubishi "Computerized Automatic Parts Search System") program here:
Stealth 316 - WINCAPS Installation
Scroll down to this area:
You can also download the files from Stealth316.com.
Directory Listing - a folder where each file for version 3.41 can be downloaded individually (for dial-up connections)
http://www.stealth316.com/misc/wincaps-setup.exe - all files for version 3.41 in a single 90-MB executable installation file (for broadband connections).
Pick which download depending on your internet connection.
Awesome, thanks!
I couldn't find the bolt parts numbers, I need the bolts the go to the flexplate to crankshaft and flexplate to flywheel for my 420a.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
