2G Replacement Horns
Justin DuBois
DSM Wiseman
3,351
3,325
Aug 15, 2019
Oakland, California
I am looking for a 2 wire pigtail that looks like the connector on the factory horn on the right, so I can connect the blade connection on the replacement without cutting the factory wire harness.
I need something to plug into this:
looks like this:
I was thinking a universal pigtail might work since it's a common connector shape, but it appears the pin spacing can be different.
I ended up cutting the plugs off the chassis harness and replacing them with blade connectors.
Two things:
1st. The horn behind the battery is thin, and tight clearance. I ended up removing the plastic half of the horn to make it fit.
2nd. The red wire gets no volts when the horn relay is triggered. The front horn gets power, but the one behind the battery, no. The wiring diagram has no connectors between the horn and the relay, so it seems like there is a break in the wire.
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G 3rd Brake Light With Trim Panel & Hardware
    2G 3rd Brake Light With Trim Panel & Hardware $85 + shipping & paypal feesYou must be...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Manual Shifter Base with Short Shifter
    2G Manual Shifter Base with Short Shifter $75 + shipping & paypal feesYou must be registered...
