AWD-Tony
- 6,787
- 3,746
- Sep 11, 2017
Cincinnati,
Ohio
So I replaced the rear differential with a spare one I picked up a while back. If I remember correctly, both rear wheels spun in the same direction with fronts grounded. With the "new" diff in, they spin the opposite direction. I haven't put fluid in it yet and both look identical. I had to swap the covers since the old one was cracked. They both had Viscous LSD B1H sticker. Could the LSD be bad?
If it does have a bad LSD, can I simply swap it from the old diff? Or do I have to shim them properly?
FYI - Car does have welded center diff.
Thanks, Tony!
Thanks, Tony!
you can still see his name so I'm deleting the pic.
