Replaced CMC now clutch is weird.
92gsxecl1pse
86
May 9, 2009
Columbus, Ohio
I recently just replaced my Clutch Master Cylinder, and now my clutch pedal will start to grab just about as soon as i start letting the clutch pedal out. I also have some clutch pedal play. I adjusted the rod it gave me a little more pedal travel but still clutch play up top..also when i rev the car up to 6k it starts to move a little, so im guessing its not fully disengaging. I have heard that the Clutch pedal assembly do intend to go bad and i know John Shep makes a great replacement, but why would this happen right after replacing the CMC. Never had the problem before. I bled the lines twice. Any advice is appreciated. Thanks.
Because it's not adjusted properly.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/vYJxQyjIhUw&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vYJxQyjIhUw&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
