removing the ac and found this
wishful_laser
242
Nov 25, 2003
springtown, Texas
i was removing my ac today the condenser and everything to make some more room under the hood.my question is that will there be any kind of leaking where the ac lines ran to? and i found that i guess it would be the oil cooler right in front of the radiator,was coming from my ac too. i want to get rid of the whole thing but two of the lines actually run to my oil filter housing. my question for that is can i bypass the oil cooler and completely take out the lines and condenser and everything or do i have to keep the condenser since it runs to my oil filter housing.
got a pic of what you are talking about. the oil cooler should be like 9in x 9in x 1.5 in. roughly. you should be able to take out all the ac stuff and leave in the oil cooler.
i wish i did. my scanner is being a @#$%^. but that is it. it looks like a mini radiator. i didnt know if i could take it out or not cause it runs to the oil filter housing.the ac lines that led to the cooler lead to the sides of the radiator too. im not sure if that is going to leak or not
they are 3 seperate units
the oil cooler
condenser
radiator
at least they are on my car. wouldnt make any sense if they were together and joined.
I have no idea of what your looking at but i think that your confusing your ac condenser with is the part that looks like a thiner radiator and sits right behind the radiator itself. there should be no lines oil or powersteering that hook to it. just the small and the big ac lines. look again and post pictures.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
