Removed Emissions Vaccuum Lines Now Problems
tight_tsi
91
Jul 21, 2006
Lincoln, Nebraska
So I removed all of the emissions vaccuum lines tonight after work per following the directions from the Taboo diagrams. I capped all 4 ports on the throttle body. Completely removed the charcoal canister and left the line to the fuel tank vented/open. Removed all the vaccuum lines associated with emissions. My wastegate is getting supplied from the J pipe, I have no mbc as of yet. The car is otherwise stock except for a 16g turbo. I also installed a new battery and new fuel filter while I had things apart. The egr is also blocked off.
I drove the car to work today, drove it around on my lunch break, and drove it home with no issues. After the above work was completed and all put back together, I went to drive it and I'm now getting a bunch of white smoke out the exhaust even while just idling. It might have a slight blue tint to it but it is mostly all white. Revving up the engine in neutral makes it a lot worse. I've double checked everything - even pulled off the intake pipe to check the turbo for shaft play, etc. It has a slight amount but the fins don't touch the sides or anything. I have the feeling it has something to do with the modifications I performed as it drove perfectly fine right before I did them.
Any suggestions/advice?? Thanks in advance -
run a it off the J pipe to the MBC then to the wastegate and have a seperate line with no T's into it running to your bov shouldnt need anything T'd into the bov line when done correctly.
