emissions removed...But no MBC
josh38127
611
Oct 2, 2009
Memphis, Tennessee
My gf who I Have flipped from ricer to turner. She wants to remove emissions EGR,vacum.... etc I showed the Taboo speed shop's diagram. She asked me if she could remove them without using a MBC? I want would happen Does anybody know?
Nothing I guess. It shows the BOV T'ed to the Intake. Then it runs to MBC then finally goes to turbo wastegate...If there is no MBC wouldn't the car just boost what the wastegate is set for..8lbs
Well, the BOV would be tee'd into a boost-source. You didn't say the year of your GF's car, but if it's a 1g, you can use the boost-source off the j-pipe, then off the wastegate for the other. If it's a 2g, you can tap the BOV-line if you can't find another. It's frowned upon, but a 2g doesn't have a source of a j-pipe stock like a 1g.
Since you don't have a MBC, just leave the stock boost-control solinoid in place until you get a MBC.
the nipple was broken. Whould the car just boost 8lbs. Thats what 14b wastegate is set to open. Right??? The car is a DD right now. We dont can't get a MBC just yet
What nipple? But yes, the stock wastegate is set for about 8lbs. You can delete the stock boost-control solinoid properly so it doesn't over-boost. You may even pick up a lb. or two. Check www.vfaq.com for the how-to.
I did it. been set up that way that for a week. I was pretty sure I was right. She saw the Aftermarket guage was reading 2lbs more than her stocker. I explained the differance between the two she understands now. She wanted to hear sombody else say it. LOL Thanks
HaHa...such faith she has ;). At least she's on the right path. It's not uncommon for the wastegate actuator to create up to 10psi of pressure on a 1g. Like Red said, just be sure she pays attention to the boost gauge, as it is also not uncommon for the original stock actuator to stick as it nears the end of it's life.
