Remove door belt trim
iSPYder
Aug 30, 2004
Havertown, Pennsylvania
I'm trying to figure out how to remove the belt trim that runs underneath the windows on a 2g Spyder (not sure if it would be different than the coupe). I've searched around but haven't found instructions for a 2g, only the 1g. On the 1g it sounds like all you need to do is remove the plug at the end of the door and pull the trim up. On my car though there are at least 2 metal Phillips head screws on either end that need to be removed and even after taking those out it didn't want to come off. It's seems like there are a few more screws holding it on within the door but they aren't visible/accessible because the interior trim is in the way.
Thanks!
Erik
Erik-
It seems like you need to remove the interior trim to get at the other screws holding it in if its in the way.
:dsm:
