recent auto dyno results,
FIBA M - EC17PSE
Supporting Vendor
6,772
5,197
Nov 1, 2008
Orlando, Florida
Not sure if its correct or if its even wheel power as the sheet states flywheel by my numbers on the dyno dynamics dyno were 175 hp And my torque was 180. Temp on the day at the venue was 31 degrees
Pic of the dyno sheet 901112 10151813624831337 2080145429 O - DSMtuners Gallery
Any input and thoughts are welcomed and if I should be happy with my numbers as I have not done alot of heavy upgrades,
Thank you
How much boost and what octane were you running? Still t25 correct?
stock boost on a t25 yes. and i was running 99 oct shell v-power nitro plus in the UK which I think is about 94 equivalent to US mon rating? i dont know this for sure though
One of the scary things i hate doing is Compression test.
why do you hate doing them?
I do mine at least once a year and all seems well. cannot remember the last readings but where good for the age of the car. roughly guessing here but my brain is telling me 182 and pretty damn close to matching all across, i think #4 was 179 or something, but this is not certain as I cant remember completely! I am due for another one just after christmas.
#s seem correct
dyno or compression #?
that chap did say to go by the maf g/s readings so i did that and he worked it out it was 193hp but i dont know enough on that to judge, but i do need to find time to calibrate my link ecu then i can get a proper reading
all dynos will be different but your numbers seem close to average for your boost and mods
ok thanks for that. as ive never taken it on before and did no research on numbers i thought i was a tad low but guess not
