2G Rear view camera wiring
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
Hi i recently got a android stereo and it came with a reverse camera. Im trying to install it buy can find any info on what wires i need to hook it up i have a diagram below. I need the wire that gose to the reverse light. A 12v power that only turns on when the reverse light turns on thanks.
Both red wires from the cam u should wire to acc or ign 12v, then the reverse sense wire from the deck directly to the reverse light signal. Ground to chassis.
This will allow you to toggle the cam on at will, as well as auto turn on for reverse.
What year is your 2g? Reverse 12v should be red/blue in driver kick.
