rear tires spinning
TurboAnything
701
12
Jun 6, 2004
Carol Stream, Illinois
Well i just tried to do a brake torque launch in my auto 1g. As the boost came up it started spinning the rear tires and every time after it did the same thing. the ground here is icy but i still think it should not do that?
That is a very odd problem. They are most likely spinning because when power braking it almost all of the brake pressure is in the front. That coupled with being on ice will let the tires spin some. That essentially is how the Viscous Coupling works. If it does it on dry payment then I would be worried.
This happens to people who brake boost auto's. I would think on a launch at a track it wouln't do it unless you build 15psi or higher. It's not good for the vcu, or center diff.
Thanks guys that explains it. After some research i found this out as well. I still have a bad pump seal and i did not want to fix it if the trans was bad.
