1G rear trans pan seal
ktime
43
Jan 1, 2012
LaGrange, North Carolina
I got a 1g what's the rear trans pan seal whats it called and where to find it not really sure what else to call it other then metal pan on the back of the auto trans
If you are talking about the large sort of "T" shaped cover, that would be the front differential cover, if it is the smaller rectangular shaped cover, that would be the idler gear cover. You can probably get the gasket(s) from one our vendors that deal with transmissions, such as IPT, Metro, Jack's or Kiggly, maybe even from JNZ out of their OEM stuff.
