1G Jeff Bush Trans pan review
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Im sure there is others out there but heres mine.
This pan is solid. Thick flange that you will never dimple. Plenty of meat if you want to add sensors on it as well.
Upon filling the trans back up I needed a full 8 quarts to top it off. This was not a full flush just a drain and pan swap.
My only issue was that my trans had some stripped holes(nothing to do with the pan) and the suck to fix on the car but made it happen.
If you want a beefy unit with more fluid capacity get this immediately!
If i remember it was only a week or 2... well worth it... and i also timeserted the trans while the pan was off so I cant strip holes anymore
Well worth the upgrade
What else is involved.... just curious... 8 quarts is plenty for me
needs a tubular crossmember if you don’t already have one and when you put it on the crossmember has to come off. Nothing major
Got it! I do have a tubular but i liked being able to pull the pan and timesert the trans without removing it.
Love these pans for sure!
