REAR SWAY BAR...need HELP ASAP
KNIGHTRIDER187
91
Feb 12, 2003
Florida/Cali,
dont have dirrections for the rear sway bar and it does not have a stock one...so if you have a picture or directions on which way i install it please reply...it is a SUSPENSION TECH rear...also do i realy need the 2 brackets that mount it to the bar to the frame
I'm guessing that's a yes, since there'd be no other way to mount it to the car...
Models that do not come with a rear stabilizer bar from the factory (models marked "see below") must purchase additional parts from Mitsubishi/Eagle/Dodge/Chysler in order to utilize the...stabilizer bars.
youll need more than just 2 brackets. You need gst/gsx rear lower control arms, endlinks and the 2 brackets that hold the bar to the crossmember, also the miscellaneous bolt/nut hardware. Also the st bar has a habit of rubbing a notch in some parts of the cross member, do a search and im pretty sure someone posted a pic of it
