Replacing rear sway bar
Seattle GST
184
Mar 11, 2004
Seattle, Washington
I currently have a OEM rear swaybar with bad bushings.
I will be upgrading with an aftermarket sway bar set. The only problem is that I have a Thermal Research cat-back. I have read a few posts that the Suspension Teniques bar will NOT fit in the rear due to the 3" exhaust piping. Therefore RM is my second choice.
By using the tuning guide, the first setup is the Addco rear swaybar, it looks preddy darn beefy, but there is no way of purchasing one, I cannot find it via google, or yahoo search engines.
Any real life experience with an upgraded sway bars would be greatly appreciated. Also, with that experience, would you think that I need to replace the mounting brackets at the same time (the bushings are shot in the back) or should I replace them with new OEM ones?
Thank you for any advice that you can give me.
I think most sway bar sets come with their own bushings. Might want to verify that before you drop more dollaz. :)
