rear passenger side wheel bearing
awd4u
90
May 17, 2010
london, ON, Canada
hey folks, Im in need of a rear passenger side wheel bearing for my 92 talon tsi awd. now my question is what do i say to the parts people? what do I need? is it a whole hub assembly that comes with everything i need? thanks.
I don't have a 1G, so you'll need an expert on those to chime in. For my 2G, the rear bearing was available as an entire hub assembly. Check out this diagram to see if it helps:
Mentor Mitsubishi Parts
From that, it looks like the bearing is available as an individual part and would most likely need to be pressed in. Hopefully a 1G person will chime in here so I don't end up misleading you. Good luck!
Your going to ask for the wheel bearing. Then your going to have to take the hub off your car, and bring it to a machine shop and have them press out the old one and press in the new one.
Thanks Ramsack, those are two really useful links. Quickly bookmarked and thrown into the DSM favorites folder...
so i can just get the whole hub assembly and it will give me everything i need?
Not on a 1G. You need to order the seals and bearings like they show in the two links ramsack posted.
Sorry to bring this back from the dead.
I thought Ebay sell complete wheel bearing & hub assembly for 1G AWD? I bought a set for the rear but it doesn't look like anything in the posts below. I hope someone can shed some lights on this.
http://www.dsmtuners.com/forums/articles-drivetrain/214904-awd-rear-axle-bearings.html
http://www.dsmtuners.com/forums/art...66-1g-awd-rear-wheel-bearing-replacement.html
Here is the set I bought from Ebay.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
