Rear passenger side wheel problem
volcomsnow245
492
May 4, 2011
chicago, Illinois
I have been searching around for awhile now and can't find a direct answer to my problem so here it is. Over the winter I slid into a curb. I was trying to stop the car from hitting it and it only hit the backtire but now it seems like when I turn right I hear a noise. Also when I'm driving at higher speeds I can feel it wobble the whole back end when I'm coming around a bend. What do you guys think the problem could be?
Could be studs not tight or loose did you take off the wheel to inspect it any shop can identify the cause or problem kinda hard to diagnose.
I haven't taken to a shop yet. I'm going to throw the spare tire on to see if it stops maybe I bent the rim. I'll also check the studs.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
