Weird passenger side widow problem
TooFastTooG
521
6
May 12, 2004
Plainfield, Illinois
Hey,
So a while ago my driver side switch to to make the passenger side window go up and down broke off. I figure no problem and I got a new one, during that time I had to just lean over and use the button on the passenger side to make the window go up and down.
So the new switch comes and I install it and now the window will not go up or down using ether switch (driver or passenger). I even put in a new passenger switch and it still does not work. I checked the fuse and it is not blown(one in motor). keep in mind that my driver side window has had no problems.
Any Ideas on this guys?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
