Rear Diff for Drag Car
Rick539
62
Oct 3, 2004
Wichita, Kansas
Could use some help on figuring out the set-up for our drag car. It is a 95 talon with a 1G methanol engine with a 2G auto trans. Cage is done and has been curbside certified to 7.50. Been talking with IPT and they can build a tranny I hope that is capable of around 900. What ideas we need is on the rear diff setup. Have sent a couple of inquires out to Strange and Moser to see if they can build a rear spool. I haven't worked with auto diffs before. Are the axle splined the same in the manual and auto diff? We are wanting to use DSS axles but understand they are for manual diffs. I do know about the gear differences. If the axle splines are the same then it should be just a gear to housing swap? Any input would be appreciated.
You should check with English Racing and see what they are running on there auto 1g, they made over 900 then swapped to an auto. I think they are making 826whp on the auto setup.
The splines are the same, just different gear ratio.
English Racing is using only the good 'ol stock 4-bolt rear end on Jeff Bush's drag car, auto gearing of course. They haven't gotten it to the track yet but they could still give some insight I'm sure.
http://www.dsmtuners.com/forums/dyno-talk/331684-our-auto-dsm-makes-816whp.html
English Racing
English gave some good feed back. And you are right about the diff not handling the twist. We ave fabricated solid bushing in the cross memeber where the diff connects and are plating the front portion of the diff on both sides. This should lock in the diff quite well. With solid brass bushings in the rear suspension and our cage load points, should make the rear diff solidly mounted
Rick I don't know the front diff gearing in a 2g auto to calc the gearing
I know the 1g inside out & the rear diff is underdriven by .00769
Locked 50/50 the rears are 66½" short over the 1/4 mile
Locked with lsds both ends, mine shows 5/16" underdriven on the rears
My compensation is 215x45x17 front & 245x40x17 rears = 5/16" diff
This rolls correctly with my odd tyres. I could overdrive by .004 if I
get 25/23 custom transfer case gears made for my 1g.
That would be 5/32" advanced at the rear instead of 5/16" under
If you look at a launch, rears bog to less circ & the fronts expand
So overdriving the rears by a poofteenth is more suited for the drags
The cheapest rotation fix is tyres by checking it on the hoist.
Cheers !
