Re-torquing head bolts
lngbrdr
225
Jan 8, 2005
melbourne, Florida
Does anyone have a link to the tightening sequence for headbolts and to what torque i should torque the stock 7-bolt headstuds to?
Thanks
This is the order for unscrewing the head bolts...just inverse the order (1 for 10, 2 for 9, etc):
My haynes manual for the 95-99 2.0 turbo motor shows that the tightening sequence is
sorry bout the bad pic i couldent figure out how up upload one.
7 5 2 4 10
9 3 1 6 8 Front of engine (cam gears)
Tourqe specs. in Ft.-lbs.
Step 1 Long bolts to 25
Step 2 Short blots to 20
Step 3 Long bolts to 50
Step 4 Short blots to 20 agian
Step 5 Long bolts to 50 agian
Step 6 Short bolts to 20 a third time
Step 7 Long bolts a ¼ turn further
Step 8 Short bolts a ¼ turn further
7 5 2 4 10
That seems pretty logical. I have always started in the middle and worked outward no matter what engine. I am not sure if Mitsu specifies differently though.
This is probably stupid but you can get to the headbolts without removing the cams? And which ones are the long ones and which ones are the whort ones?
Yes you can it all comes out in one peice and im not sure which ones are long and short but you should be able to tell when you take it out. But dont reuse them. your best bet is to go with a set of ARP head studs.
Anyone ever put a set of ARP studs in without pulling the head? I had heard that there were some clearance issues do to the fact that the ARP studs are longer than the stock bolts. Anyone know for sure?
If your going to go with a set of ARP's then you should also go with a new metal head gasket cause theres relly no sense of puting them on if the gasket is not any good. But if you have already put a new gasket on recently then theres no harm in trying to put them on without remoing the head.
  • Wanted 6 bolt NT water pipe
    • chrisman287
