slow_tsi
- 58
- 0
- Apr 3, 2008
Chillicothe,
Ohio
2g awd talon 2600lb act, this is the 2nd clutch it is rapid clicking when u put in the clutch. after a few times of pushing the clutch it clicks constantly. it increases speed with rpm, when you put in the clutch it bogs the car has a shep stage 3 trans, and i just replaced the clutch pressure plate and throw out bearing today. the noise was there before the clutch was replaced i thought it was the tob or maybe bent pressure plate finger, but apparently not im lost so lets hear it. all theories welcome.
with a stethoscope sounds like its coming from drivers side crank area steth on engine behind crank pulley im trying to be thorough here
I hate to bust your balls, but man that was absolutely miserable to read and most knowledgable people on here are going to choose to ignore a post if they have to stumble through it just to try to read what you have written.
