spyderdrifter
- 5,434
- 864
- Jul 11, 2009
Somewhere in,
Colorado
So I got to work this morning and sat there in my car for 10-15 minutes like usual just to let my oil cool down and so forth. After that I noticed my temp gauge reading way hotter than it should and my coolant was boiling in the over flow reservoir. The last time I worked on the cooling system was back in February when I put my Mishimoto radiator back in. The system was fully burped and replaced the rad cap the same day. The water pump, thermostat, and both temp sensors were replaced last summer. Since the rad swap, the cooling system hasn't had any issues and has run just fine and now this. The drive to work showed no abnormal Temps either. Any ideas out there? My only thought is maybe the water pump since it's not an oem unit, but there's NO leaks anywhere. My parts list is current except the fmic has NOT been installed yet. I know that will cause higher Temps and have planned for that once I do install it.
