randomly died
99 gs iowa
335
May 29, 2011
moravia, Iowa
have a 97 gst bone stock besides a fmic, today i was driving down the road and it randomly died and will not start back up, i cant seem to be able to figure out what it is and it isnt throwing any check engine light or anything, its getting fuel, i checked spark plugs an they seem worn out, but ive never heard of sparkplugs making a car die like this? any ideas on what it could be? :pray:
The only times my DSM's ever died liked that was because the capacitors in ecu had failed..
May be your timing belt. That's where I would look. Have you replaced it lately?
I have to agree with bomb91, I bought my car drove it for 4 days and went to start it and nothing. Changed the ignition transistor, coil packs, plugs wires. Made a rookie mistake and never checked for spark initially. Well my ECU was done because of the capacitors were no good. Swapped in a new ECU and started right up. If you have a Hanes manual ect. it shows you how you can check your ignition components to see if they are in spec. I would pull the ECU takes 10-15 minutes crack the cover and inspect the capacitors.
