420A Radiator Fan Wiring?
Nova95
70
10
Jul 7, 2022
Kirbyville, Missouri
IDK why but previous owner cut connector for the radiator fan on the passenger side. I'd like to get it running again. I've looked at some diagrams but they left me more confused.
Radiator fan has black, blue. Car wiring side has black, blue, blue+white, blue+black. Anyone able to tell me where the blue+white, blue+black goes? Thank you.
96 Eclipse RS NT 420A
That's normal. It's a 4 pin connector, but only 2 wires should be present on the fan side.
I'm assuming you have an aftermarket 1 speed fan.
If so, connect the harness connector blue and blue/white wires to your fan's positive. Then connect the harness connector black and blue/black wires to your fan's negative. This will allow your fan to come on when either the condenser fan hi or lo (or both) relay activates.
Perfect I'll do this after work, thank you so much!
