rad, fan do not fit
sharky559
191
Mar 6, 2010
Sanger, California
Okay so i installed a evo 3 turbo. now the fans do not fit. need help could it be the j pipe:confused:
My evo 3 fit with stock fan and I am sure alot of peoples have. What j pipe do you have? Pic always help. It should be obvious what is blocking when you try to install it if you look at it when you try to install the fan theres not alot right there in the front of the engine.
cut some of the lip off the black plastic housing, just make sure you have clearance between the fan and radiator. It's not rocket science
