Quick Log
2GturboTALON
607
6
Nov 26, 2002
St. Peters, Missouri
I just bought a new awd 2g Talon with the following done to it.
14g turbo (what i was told)
full apexi catback
Apexi twin chamber bov
here is a quick log i did. Tell me what u guys think.
If i'm reading that right your getting 20 degree's of peak timing which should be impossible as the most the stock ECU gives is 16, so that's a little weird...
Another thing I just noticed, you never went more than 80% throttle so either you have a blockage under the pedal or the cable needs adjusting or you just weren't pushing hard enough, this would also explain the timing.
alex99gst said:
Can you log knock? That is what we really need to see. Do a 3rd gear pull up to redline and log rpm, timing, knock, and O2 only.:thumb: Then we can start helping you.
It's a 2g so no knock.
But yes 3rd gear from 2500 to 7k and log rpm,timing, o2 1, and airflow of you want.
